This command removes previously defined L4 listening ports (sockets).
| listening | Configures captive portal HTTP listening ports (up to three L4 ports). |
| socket_list | List of L4 listening ports that you want removed, separated by commas (for example: 80,8080,2000). |
| all | Removes all listening L4 ports. |
N/A
The following example removes captive portal L4 listening ports 80 and 8080:
# unconfigure policy captive-portal listening 80,8080
The following example removes all defined captive portal L4 listening ports:
# unconfigure policy captive-portal listening all
This command was first available in ExtremeXOS 22.3.
